Ir para o conteúdo principal
Texas Instruments TI-80 Back Casing Replacement
O que você precisa
  1. Texas Instruments TI-80 Back Casing Replacement, Batteries: passo 1, imagem 1 %32
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Back Casing Replacement: passo 2, imagem 1 %32
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Back Casing Replacement, Back Case: passo 3, imagem 1 %32 Texas Instruments TI-80 Back Casing Replacement, Back Case: passo 3, imagem 2 %32 Texas Instruments TI-80 Back Casing Replacement, Back Case: passo 3, imagem 3 %32
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
Conclusão
Calvin
Membro desde: 01/08/15
201 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 272
