Ir para o conteúdo principal
Texas Instruments TI-5130 Power Cord Replacement
O que você precisa
  1. Texas Instruments TI-5130 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 Texas Instruments TI-5130 Power Cord Replacement, Power Cord: passo 1, imagem 2 %32
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Power Cord Replacement: passo 2, imagem 1 %32 Texas Instruments TI-5130 Power Cord Replacement: passo 2, imagem 2 %32
    • Remove the top cover.
    • Gently pull up on the power cord to remove it from the back cover.
  3. Texas Instruments TI-5130 Power Cord Replacement: passo 3, imagem 1 %32 Texas Instruments TI-5130 Power Cord Replacement: passo 3, imagem 2 %32
    • This step is optional; however it makes it easier to work.
    • Using a PH1 screwdriver remove the two 10mm screws that hold down the transformer.
    • Gently remove the transformer.
    • Make sure that the calculator is not plugged in.
  4. Texas Instruments TI-5130 Power Cord Replacement: passo 4, imagem 1 %32 Texas Instruments TI-5130 Power Cord Replacement: passo 4, imagem 2 %32
    • Use a wire cutter to cut off the white cap and expose the wires. Try to cut close to the tip of the white cap - to leave as much wire as possible.
    • Note that there are 2 sets of wires connected to the power cord. Do each set of wires separately.
  5. Texas Instruments TI-5130 Power Cord Replacement: passo 5, imagem 1 %32 Texas Instruments TI-5130 Power Cord Replacement: passo 5, imagem 2 %32
    • Use a wire stripper to remove 1/2” of the protective covering on each of the wires.
  6. Texas Instruments TI-5130 Power Cord Replacement: passo 6, imagem 1 %32 Texas Instruments TI-5130 Power Cord Replacement: passo 6, imagem 2 %32
    • Twist the exposed section of the 2 wires together.
    • Twist a new cap over the exposed wires. Make sure that the cap covers all of the exposed wire.
    • Repeat steps 4-6 for the second set of wires.
  7. Texas Instruments TI-5130 Power Cord Replacement: passo 7, imagem 1 %32
    • Replace the transformer and ensure that the new wire caps fit in the space shown.
    • Plug in the new power cord and test the calculator before replacing the top cover.
Conclusão
Uma outra pessoa concluiu este guia.
Shannon Perkins
Membro desde: 09/17/15
652 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 490
