Ir para o conteúdo principal
Texas Instruments TI-30X IIS Battery Replacement
O que você precisa
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: passo 1, imagem 1 %32 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: passo 1, imagem 2 %32 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: passo 1, imagem 3 %32
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: passo 2, imagem 1 %32 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: passo 2, imagem 2 %32
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: passo 3, imagem 1 %32 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: passo 3, imagem 2 %32 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: passo 3, imagem 3 %32
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: passo 4, imagem 1 %32 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: passo 4, imagem 2 %32 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: passo 4, imagem 3 %32
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: passo 5, imagem 1 %32
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
Conclusão
20 outras pessoas executaram este guia.
Ryan
Membro desde: 03/01/15
515 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 56
Últimos 30 dias: 419
Duração total: 32,867
