Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Testing Power Cord Continuity
O que você precisa
  1. Testing Power Cord Continuity, Testing Power Cord Continuity: passo 1, imagem 1 %32
    • Unplug the power cord from the game console and from the AC outlet. Failure to do so can result in electrical shock or death.
    • Set the multimeter to continuity test mode.
    • The setting is symbolized by a "volume indicator" as seen in the picture. If the meter is set to the correct mode, you should hear the meter beep when the leads are touched together.
    • Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
  2. Testing Power Cord Continuity: passo 2, imagem 1 %32
    • Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
    • If there is an adequate electrical connection, the multimeter will beep. If it does not beep the first time, try using the lead to touch the other prong.
    • Repeat the above directions in step 2 for the other outlet and prong of the power cord.
    • If the multimeter fails to beep on any of the occasions outlined above, your power cord is open. In other words, you will need to replace the power cable.
  3. Testing Power Cord Continuity: passo 3, imagem 1 %32
    • Once you have verified that the power cord provides an adequate electrical connection, you will have to test that the cable is not shorted.
    • Test for a potential short circuit by touching each prong on the AC side of the power cord.
    • If the multimeter beeps, your power cord is bad and must be replaced immediately.
    • If your power cord is shorted, do not attempt to replug the cord into the AC outlet.
    • If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
Linha de Chegada
146 outras pessoas executaram este guia.
Darren Chan
Membro desde: 10/28/09
5.321 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-1, Regan Fall 2009 Membro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
Membros da 5
Autoria de 21 guias
13 comentários
Thank you very much.
Kaky Jerry - Responder
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Muhammad Imran - Responder
Brilliant love it
Liam Breen - Responder
Worked like a charm I feelik an electrician
hadpaulkh - Responder
I found this really wonderful and useful with details explained very well. I was always wondering what the electricians do with a multimeter. Now iI would buy one multimeter and do this on my own. Great and cool guide. Write more guides for other tests and verification.
Avinash S - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 109
Últimos 7 dias: 552
Últimos 30 dias: 2,605
Duração total: 228,840
