Introdução
A detailed guide on how to use a continuity tester to check for adequate electrical connection on a power cord.
Ferramentas
Peças
Nenhum componente especificado.
Set the multimeter to continuity test mode.
Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
Repeat the above directions in step 2 for the other outlet and prong of the power cord.
Est-il possible de brancher sur une autre prise alimentée pour savoir si cordon et appareil sont non défectueux ??? Sans danger; faire sauter fusibles etc. Merci.
Test for a potential short circuit by touching each prong on the AC side of the power cord.
If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
is there a guide like this very useful one but to test the surface power cords ?
136 outras pessoas concluíram este guia.
15 comentários
Great Article,you can use a little bubble to let electric current light the bubble,make sure use the correct voltage of ,Example ,if you are in Europe,then you need to use 220V Europe power cord http://www.yunhuanelectric.com/Europe-po... to test.
Thank you very much.
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Brilliant love it
Superb...thanks a lot!!
Now I know how to test a power cord.
How do I test a switch?
Can you do a continuity test on the Xbox One Original CONSOLE ?
An electrician respond your call within an hour in dubai . so they have guideline to do electrical work with safety. <a href="https://handyman-dubai.com/electrician-d...>electrician in dubai</a> they have tools of testing power all time with them . they resolve issue with that.
