Ir para o conteúdo principal
Tesla Model S Key Fob Battery Replacement
O que você precisa
  1. Tesla Model S Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 Tesla Model S Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32 Tesla Model S Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 3 %32
    • Remove the protective case from the key fob.
    • This step is optional; not everyone has a protective case.
    Pergunte ao FixBot
  2. Tesla Model S Key Fob Battery Replacement: passo 2, imagem 1 %32 Tesla Model S Key Fob Battery Replacement: passo 2, imagem 2 %32 Tesla Model S Key Fob Battery Replacement: passo 2, imagem 3 %32
    • Insert the flat end of a spudger into the notch, and gently pry the key fob open along the seam.
    • Separate the cover from the key fob.
    Pergunte ao FixBot
  3. Tesla Model S Key Fob Battery Replacement: passo 3, imagem 1 %32 Tesla Model S Key Fob Battery Replacement: passo 3, imagem 2 %32 Tesla Model S Key Fob Battery Replacement: passo 3, imagem 3 %32
    • Insert the flat end of a spudger into the entry point at the top of the key fob.
    • Lightly push the spudger under the battery.
    • Remove the battery from the key fob.
    Pergunte ao FixBot
  4. Tesla Model S Key Fob Battery Replacement: passo 4, imagem 1 %32 Tesla Model S Key Fob Battery Replacement: passo 4, imagem 2 %32 Tesla Model S Key Fob Battery Replacement: passo 4, imagem 3 %32
    • With your fingers, insert a new CR2032 battery into the opening.
    • Ensure correct placement of the battery by having the writing facing up toward you and the blank side with a number facing down inside the battery opening.
    • Push the battery with your thumb to lock it into place.
    Pergunte ao FixBot
  5. Tesla Model S Key Fob Battery Replacement: passo 5, imagem 1 %32 Tesla Model S Key Fob Battery Replacement: passo 5, imagem 2 %32 Tesla Model S Key Fob Battery Replacement: passo 5, imagem 3 %32
    • To close the key fob, enter the wider side of the cover into the opening in the middle of the key fob.
    • You should see the end of the cover a little popped out.
    • With your thumb and pointer finger push together the cover and the key fob to allow for the key fob to be securely closed.
    Pergunte ao FixBot
  6. Tesla Model S Key Fob Battery Replacement: passo 6, imagem 1 %32 Tesla Model S Key Fob Battery Replacement: passo 6, imagem 2 %32 Tesla Model S Key Fob Battery Replacement: passo 6, imagem 3 %32
    • This step is optional (not everyone has a case).
    • Place the key fob into the opening of the case.
    Pergunte ao FixBot
Linha de Chegada
3 outras pessoas executaram este guia.
Equipe
2Comentários do guia
Really, that tip was helpful, the last time i my model s tesla key fob's battery was dead, I order another on amazon, and some tips online here on tesla key fob programming. At first, I was a little bit skeptical given that I have not done such a thing before on my tesla. However, the process was really simple and the guide on the site was helpful.
Ayo Idowu - Responder Compartilhar
hello thanks for WRONG INFORMATION on 2022 s key fob it does not take 2032 battery
masterchief - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 111
Ao todo: 7,248
