Ir para o conteúdo principal
Tesla Model 3 Keyfob Battery Replacement
O que você precisa
Vídeo de Apresentação
  1. Tesla Model 3 Keyfob Battery Replacement, Prep: passo 1, imagem 1 %32
    • Prepare a surface to work on (ensure it's won't damage the piano black exterior coating)
    • Gather your key fob and a small plastic spudger
  2. Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: passo 2, imagem 1 %32 Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: passo 2, imagem 2 %32 Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: passo 2, imagem 3 %32
    • Using a small pry tool, gently press into the small indent near the front of the key fob while pressing up to pop off the battery cover.
    • Remove the coin-cell battery type CR2032 by prying upwards in the small recess
    • Insert a fresh CR2032 coin cell battery being sure to match the correct polarity of the original
    • If all you want to do is replace the battery, stop here. Otherwise check out my other guide for a full teardown!
Conclusão
Uma outra pessoa concluiu este guia.
IZ Labs
Membro desde: 08/13/17
217 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 40
Ao todo: 434
