Ir para o conteúdo principal
Tent Pole Shock Cord Replacement
O que você precisa
  1. Tent Pole Shock Cord Replacement, Tent Pole Shock Cord: passo 1, imagem 1 %32
    • Remove the old shock cord from the tent poles.
  2. Tent Pole Shock Cord Replacement: passo 2, imagem 1 %32
    • Measure and cut the string to the length of one tent pole piece.
    • Be sure to leave enough room on each end for knots.
  3. Tent Pole Shock Cord Replacement: passo 3, imagem 1 %32
    • Tie the string to the end of the shock cord.
  4. Tent Pole Shock Cord Replacement: passo 4, imagem 1 %32 Tent Pole Shock Cord Replacement: passo 4, imagem 2 %32
    • Use your hands or pliers to flatten out a bobby pin.
    • Any long, thin, metal object will work to help feed the string and cord through the poles.
  5. Tent Pole Shock Cord Replacement: passo 5, imagem 1 %32
    • Tie the string around the end of the bobby pin.
    • The string and bobby pin will be used to feed the shock cord through the pole.
  6. Tent Pole Shock Cord Replacement: passo 6, imagem 1 %32 Tent Pole Shock Cord Replacement: passo 6, imagem 2 %32 Tent Pole Shock Cord Replacement: passo 6, imagem 3 %32
    • Drop the bobby pin and string through the tent pole pieces one by one.
    • Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
  7. Tent Pole Shock Cord Replacement: passo 7, imagem 1 %32 Tent Pole Shock Cord Replacement: passo 7, imagem 2 %32
    • Once the last piece has been threaded, untie or cut the string from the shock cord.
    • Tie a large knot against the right end of the last piece.
    • The knot must be large enough to prevent the shock cord from slipping through the pole.
  8. Tent Pole Shock Cord Replacement: passo 8, imagem 1 %32 Tent Pole Shock Cord Replacement: passo 8, imagem 2 %32
    • Connect the tent poles.
  9. Tent Pole Shock Cord Replacement: passo 9, imagem 1 %32
    • Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
    • Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
  10. Tent Pole Shock Cord Replacement: passo 10, imagem 1 %32 Tent Pole Shock Cord Replacement: passo 10, imagem 2 %32
    • Tie a large knot around the tent pole end piece.
    • Fit the end piece into the left end of the first pole.
    • If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
  11. Tent Pole Shock Cord Replacement: passo 11, imagem 1 %32
    • Disconnect the pole pieces.
    • Fold the pieces to test the shock cord tension.
    • If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
Conclusão
3 outras pessoas executaram este guia.
Kelsea Weber
Membro desde: 11/12/15
20.558 Reputação
Autoria de 32 guias
Equipe
iFixit, Team S1-G1, Weber Summer 2018 Membro de iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
Membros da 5
Autoria de 43 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 20,886
