Ir para o conteúdo principal
Tengda S5 Plus Speakers Replacement
O que você precisa
  1. Tengda S5 Plus Speakers Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the phone screen-side down.
  2. Tengda S5 Plus Speakers Replacement: passo 2, imagem 1 %32 Tengda S5 Plus Speakers Replacement: passo 2, imagem 2 %32
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Speakers Replacement, Speakers: passo 3, imagem 1 %32
    • Using either your thumb or an iFixit opening tool, remove the battery and set it aside.
  4. Tengda S5 Plus Speakers Replacement: passo 4, imagem 1 %32
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
  5. Tengda S5 Plus Speakers Replacement: passo 5, imagem 1 %32 Tengda S5 Plus Speakers Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Speakers Replacement: passo 6, imagem 1 %32 Tengda S5 Plus Speakers Replacement: passo 6, imagem 2 %32
    • Using an iFixit opening tool, remove the speakers.
    • Do not be afraid to use a little force. The speakers are glued onto the phone, not wired.
Conclusão
Andrew Lam
Membro desde: 04/23/15
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-9, Amido Spring 2015 Membro de Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 459
