Ir para o conteúdo principal
Tengda S5 Plus Rear Camera Replacement
O que você precisa
  1. Tengda S5 Plus Rear Camera Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the phone screen-side down.
  2. Tengda S5 Plus Rear Camera Replacement: passo 2, imagem 1 %32 Tengda S5 Plus Rear Camera Replacement: passo 2, imagem 2 %32
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Rear Camera Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Rear Camera Replacement, Rear Camera: passo 4, imagem 1 %32
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Rear Camera Replacement: passo 5, imagem 1 %32 Tengda S5 Plus Rear Camera Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Rear Camera Replacement: passo 6, imagem 1 %32
    • Place the phone facing screen down.
    • Using the plastic prying tool, gently disconnect the black connector cable.
    • The connector cable should easy snap out with little force.
  7. Tengda S5 Plus Rear Camera Replacement: passo 7, imagem 1 %32
    • Using the plastic prying tool, pry the camera from the tape holding it in place.
    • Be careful not to rip the tape.
Conclusão
Jholmesford
Membro desde: 04/21/15
188 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-9, Amido Spring 2015 Membro de Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 296
