Ir para o conteúdo principal
Tengda S5 Plus Home Button Replacement
O que você precisa
  1. Tengda S5 Plus Home Button Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the phone screen-side down.
  2. Tengda S5 Plus Home Button Replacement: passo 2, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 2, imagem 2 %32
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Home Button Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Home Button Replacement, Home Button: passo 4, imagem 1 %32
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Home Button Replacement: passo 5, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, create a small gap between the front screen and the metal casing. Slide the plastic opening tool around the phone counterclockwise to make this gap around the entire phone.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Home Button Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Lay your device with the screen faced down.
    • Using tweezers, lift the two pieces of yellow tape holding the wire in place.
  7. Tengda S5 Plus Home Button Replacement: passo 7, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 7, imagem 2 %32
    • Using the tweezers again, grasp the wire and free it from the crevice.
    • This will provide slack for you to work with the lower motherboard.
  8. Tengda S5 Plus Home Button Replacement: passo 8, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 8, imagem 2 %32 Tengda S5 Plus Home Button Replacement: passo 8, imagem 3 %32
    • Remove the silver tape that holds the lower motherboard to the front panel of the phone.
  9. Tengda S5 Plus Home Button Replacement: passo 9, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 9, imagem 2 %32
    • Using your fingers, or the Metal Spudger, disconnect the black cable connector.
    • The cable connector should easy snap out with little force.
  10. Tengda S5 Plus Home Button Replacement: passo 10, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 10, imagem 2 %32 Tengda S5 Plus Home Button Replacement: passo 10, imagem 3 %32
    • Using your fingers, slide the lower motherboard towards you.
    • The lower motherboard will still be attached to the front panel by a red and blue cable on the left side and a long silver wire on the right side, but you should now have visibility of the home button.
  11. Tengda S5 Plus Home Button Replacement: passo 11, imagem 1 %32 Tengda S5 Plus Home Button Replacement: passo 11, imagem 2 %32
    • Clean away any dirt from the back side of the lower motherboard, underneath the charging port.
    • Using tweezers, grasp and remove the home button.
Conclusão
Kenny Levy
Membro desde: 04/20/15
125 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-9, Amido Spring 2015 Membro de Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 496
