Ir para o conteúdo principal
Tello Quadcopter Propeller Replacement
O que você precisa
  1. Tello Quadcopter Propeller Replacement, Propeller: passo 1, imagem 1 %32
    • Identify the propeller being replaced.
    • Gather the required materials.
  2. Tello Quadcopter Propeller Replacement: passo 2, imagem 1 %32 Tello Quadcopter Propeller Replacement: passo 2, imagem 2 %32
    • Next, remove the battery by grasping each side and pulling it out.
  3. Tello Quadcopter Propeller Replacement: passo 3, imagem 1 %32 Tello Quadcopter Propeller Replacement: passo 3, imagem 2 %32 Tello Quadcopter Propeller Replacement: passo 3, imagem 3 %32
    • Remove the propeller by inserting the provided tool between the propeller and drone.
    • Needle nose pliers can be used instead. Use the pliers to grasp directly below the propeller.
    • Gently lift the propeller from the socket using your choice of tool.
  4. Tello Quadcopter Propeller Replacement: passo 4, imagem 1 %32 Tello Quadcopter Propeller Replacement: passo 4, imagem 2 %32 Tello Quadcopter Propeller Replacement: passo 4, imagem 3 %32
    • After removing the old propeller, orient the new propeller over the empty socket.
    • Insert a new propeller by applying force. The propeller should snap into place.
Conclusão
You have successfully completed replacing the damaged propellor.
Cody White
Membro desde: 10/08/20
109 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 2,194
