Introdução
I've repaired this problem several times using this method and it works well.
O que você precisa
Ferramenta utilizada nesse passo:Desoldering Pump$3.99
Use a soldering iron, and solder sucker to remove excess solder from the connector area. You can also use solder-absorbing braided wick.
Align the connector, ensuring the center pin can reach the the spot on the board where it needs to be re-connected.
Solder the barrel of the connector to the metal bracket first, try not to let it get too hot. You may want to use a solder gun with dual heat of at least 50 watts for this part.
When that's done don't forget to solder the center pin to the board using as little solder as possible, to ensure there's no grounding to the metal cover.
Carefully replace the plastic cover. Replace cover screws.
No Phosphorus (P). The phosphors contain Cadmium (Cd). The CRT glass is made with Barium (Ba) and Lead (Pb). Vacuum is not inherently a danger. Implosion is very unlikely. I have broken many a CRT and it takes quite an effort unless you smack it on the relatively fragile neck. No dramatic explosion. No shards of flying glass. Just a crack and a whistle and cursing.
8 outras pessoas executaram este guia.
6 comentários
cara memperbaiki warna
where can i get the connectors?
C'est très intéressant, Mais seulement si vous pouvez traduire en français
11.11.16 Francais en anglaise= French to english. It's very interesting. I only wish u'd translate into French!
Hi. Finding this post ten years after the fact. My problem is that a coax cable pin connector accidentally broke off inside the coax port. Wondering if it's possible to push the broken piece back out of the port from the inside, if there's access to the port's hole from the inside of the chassis? Thanks much. Be blessed today!
