Introdução
I've repaired this problem several times using this method and it works well.
O que você precisa
Use a soldering iron, and solder sucker to remove excess solder from the connector area. You can also use solder-absorbing braided wick.
Align the connector, ensuring the center pin can reach the the spot on the board where it needs to be re-connected.
Solder the barrel of the connector to the metal bracket first, try not to let it get too hot. You may want to use a solder gun with dual heat of at least 50 watts for this part.
When that's done don't forget to solder the center pin to the board using as little solder as possible, to ensure there's no grounding to the metal cover.
8 outras pessoas executaram este guia.
6 comentários
cara memperbaiki warna
where can i get the connectors?
C'est très intéressant, Mais seulement si vous pouvez traduire en français
11.11.16 Francais en anglaise= French to english. It's very interesting. I only wish u'd translate into French!
