Ferramentas
Peças
The removal of the power switch is quite simple. First, open the case by removing all the screws on the rear panel marked with an arrow. (ATTENTION: different lengths and thickness! - when unscrewing remember which screw belongs where.
Then carefully lift off the back panel. Disconnect cables that prevent the rear panel from lifting off. Now, use a pair of needle nose pliers to squeeze the retaining clips that hold the switch in the TV housing and unclip the switch from the TV housing. (if necessary, use a flat screwdriver)
As already mentioned - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the back panel and screw in the screws again where they were screwed out.
2 outras pessoas concluíram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
