Ir para o conteúdo principal
Tektro Aires Disc Brakes Brake Pad Replacement
O que você precisa
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: passo 1, imagem 1 %32
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: passo 2, imagem 1 %32 Tektro Aires Disc Brakes Brake Pad Replacement: passo 2, imagem 2 %32
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: passo 3, imagem 1 %32
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: passo 4, imagem 1 %32
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: passo 5, imagem 1 %32
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: passo 6, imagem 1 %32
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
Conclusão
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 51
Últimos 30 dias: 210
Duração total: 3,915
