Introdução
If your Tekk Pro Edition Monster Jam Mini Hoop door hook becomes loose or has broken off and you're unable to find an OEM part, use a C-bracket to create a new door hook.
The Tekk Pro Edition Monster Jam Mini Hoop allows you to play hoops inside by placing the hoop on a door. If you've been playing too vigorously or someone decides to demonstrate their dunking abilities resulting in a bent door hook, follow this guide.
This repair requires the use of a power drill so if you're not experienced, ask for help. Take all necessary safety precautions for using power tools, such as safety goggles, etc.
O que você precisa
Use a Phillips #00 screwdriver to remove the two screws attaching the door hook to the backboard.
C-bracket will be a replacement for the original door hook that came with the mini hoop.
