Ir para o conteúdo principal
Tefal Thick N Thin Toaster 815032 Side Panels Replacement
O que você precisa
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: passo 1, imagem 1 %32 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: passo 1, imagem 2 %32 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: passo 1, imagem 3 %32
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: passo 2, imagem 1 %32
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: passo 3, imagem 1 %32 Tefal Thick N Thin Toaster 815032 Side Panels Replacement: passo 3, imagem 2 %32
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
82.822 Reputação
Autoria de 203 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.457 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 193
