Ir para o conteúdo principal
Teenage Engineering OP-Z Battery Replacement
O que você precisa
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: passo 1, imagem 1 %32 Teenage Engineering OP-Z Battery Replacement, Back Cover: passo 1, imagem 2 %32 Teenage Engineering OP-Z Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: passo 2, imagem 1 %32 Teenage Engineering OP-Z Battery Replacement: passo 2, imagem 2 %32
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: passo 3, imagem 1 %32
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: passo 4, imagem 1 %32 Teenage Engineering OP-Z Battery Replacement, Battery: passo 4, imagem 2 %32
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: passo 5, imagem 1 %32 Teenage Engineering OP-Z Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
Conclusão
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
4 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
117.756 Reputação
Autoria de 188 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.541 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 44
Últimos 30 dias: 155
Duração total: 6,927
