Ir para o conteúdo principal
Teenage Engineering OP-1 UI Board Replacement
O que você precisa
  1. Teenage Engineering OP-1 UI Board Replacement, key removal: passo 1, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement, key removal: passo 1, imagem 2 %32 Teenage Engineering OP-1 UI Board Replacement, key removal: passo 1, imagem 3 %32
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 UI Board Replacement, removing scissors mechanisms: passo 2, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement, removing scissors mechanisms: passo 2, imagem 2 %32
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 UI Board Replacement, unscrew keyboard: passo 3, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement, unscrew keyboard: passo 3, imagem 2 %32 Teenage Engineering OP-1 UI Board Replacement, unscrew keyboard: passo 3, imagem 3 %32
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 UI Board Replacement, Keyboard Connection: passo 4, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement, Keyboard Connection: passo 4, imagem 2 %32
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
    • When installing the new keyboard, make sure to remove the protective film underneath the screen.
    • The OP-1 has a mode to test specific functions. You can enter it by holding the "COM" button while powering on, then choose the function test (2). You don't have to complete every test and can power off after the keyboard test.
  5. Teenage Engineering OP-1 UI Board Replacement, UI Board: passo 5, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement, UI Board: passo 5, imagem 2 %32 Teenage Engineering OP-1 UI Board Replacement, UI Board: passo 5, imagem 3 %32
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Be careful since the flex cable is still connected.
    • Make sure the display won't be damaged when you flip it over to the front to access the UI board.
  6. Teenage Engineering OP-1 UI Board Replacement: passo 6, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement: passo 6, imagem 2 %32
    • Unplug the DSP flex cable from the UI board.
    • Unplug the speaker cable from the UI board.
  7. Teenage Engineering OP-1 UI Board Replacement: passo 7, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement: passo 7, imagem 2 %32 Teenage Engineering OP-1 UI Board Replacement: passo 7, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the five screws on the UI board.
    • To each screw there is a thick washer to fix the board. Don't loose them.
  8. Teenage Engineering OP-1 UI Board Replacement: passo 8, imagem 1 %32 Teenage Engineering OP-1 UI Board Replacement: passo 8, imagem 2 %32 Teenage Engineering OP-1 UI Board Replacement: passo 8, imagem 3 %32
    • Now the UI board is free to take out. You can grab it by the knobs and start lifting it on the right side half way out.
    • On the left side the speaker and its cable might be in the way to get it out straight. Just move it diagonally to the right to get it out completely.
    • Make sure the black plastic mat underneath the UI board stays inside.
    • After reassembling you want to check the board with the internal test function. You can enter it by holding the "COM" button while powering on, then choose the function test (0).
Conclusão
10 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
117.598 Reputação
Autoria de 188 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
2 comentários
Can anyone recommend a good adhesive tape to fix the screen in place after doing the repair?
ossian moncreiffe - Responder
No need to replace the adhesive tape as long as you leave it attached to the op1 or to the back of the display itself. So when you go to put everything back together, slot the display back into place, the adhesive tape that is there should stick very gently and when you go to put the keyboard with the display glass back, everything will be held in place.
Also, this guide skips over detaching the ribbon cables when you are removing the keyboard, the two connectors each have two (2 on each port) very small black colored locking mechanisms on the left and right of the cable's port, using a spudger you can push those locking mechanisms up about 2mm, and the ribbons should detach from the ui board seamlessly allowing you to gently pull them out. When putting it back together, insert the ribbon cable evenly to the new port, and push the locking mechanisms into place (reverse from what you did before).
sahdudeone - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 90
Duração total: 10,584
