Ir para o conteúdo principal
Teddy Ruxpin Arm Button Replacement
O que você precisa
  1. Teddy Ruxpin Arm Button Replacement, Battery: passo 1, imagem 1 %32 Teddy Ruxpin Arm Button Replacement, Battery: passo 1, imagem 2 %32
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Arm Button Replacement: passo 2, imagem 1 %32
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Arm Button Replacement: passo 3, imagem 1 %32
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Arm Button Replacement, Arms: passo 4, imagem 1 %32 Teddy Ruxpin Arm Button Replacement, Arms: passo 4, imagem 2 %32 Teddy Ruxpin Arm Button Replacement, Arms: passo 4, imagem 3 %32
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Arm Button Replacement: passo 5, imagem 1 %32
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Arm Button Replacement: passo 6, imagem 1 %32 Teddy Ruxpin Arm Button Replacement: passo 6, imagem 2 %32 Teddy Ruxpin Arm Button Replacement: passo 6, imagem 3 %32
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Arm Button Replacement: passo 7, imagem 1 %32 Teddy Ruxpin Arm Button Replacement: passo 7, imagem 2 %32
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Arm Button Replacement: passo 8, imagem 1 %32 Teddy Ruxpin Arm Button Replacement: passo 8, imagem 2 %32
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Arm Button Replacement: passo 9, imagem 1 %32
    • Unplug the arms from the main body.
Conclusão
4 outras pessoas executaram este guia.
Lauren
Membro desde: 01/23/20
220 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G5, White Winter 2020 Membro de Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
Membros da 4
Autoria de 7 guias
3 comentários
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - Responder
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - Responder
So has anyone figured out how to replace the button?
knrobinson83 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 921
