Ir para o conteúdo principal
Technique - Test the Battery
O que você precisa
  1. Technique - Test the Battery, Technique - Test the Battery: passo 1, imagem 1 %32 Technique - Test the Battery, Technique - Test the Battery: passo 1, imagem 2 %32 Technique - Test the Battery, Technique - Test the Battery: passo 1, imagem 3 %32
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: passo 2, imagem 1 %32 Technique - Test the Battery: passo 2, imagem 2 %32
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: passo 3, imagem 1 %32 Technique - Test the Battery: passo 3, imagem 2 %32
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Conclusão
Uma outra pessoa concluiu este guia.
Melinda Phan
Membro desde: 04/17/11
438 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 9-64, Walters Spring 2011 Membro de Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
Membros da 5
Autoria de 18 guias
2 comentários
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Responder
yes,not tablet with battery removal difficult
paulbeames7 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 35
Duração total: 10,154
