Ir para o conteúdo principal
Teac DC-D2831 Drive Belt replacement
O que você precisa
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: passo 1, imagem 1 %32 Teac DC-D2831 Drive Belt replacement, Drive Belt: passo 1, imagem 2 %32
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: passo 2, imagem 1 %32
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: passo 3, imagem 1 %32 Teac DC-D2831 Drive Belt replacement: passo 3, imagem 2 %32 Teac DC-D2831 Drive Belt replacement: passo 3, imagem 3 %32
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: passo 4, imagem 1 %32
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
Conclusão
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
Charles Lockner
Membro desde: 09/17/12
115 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-61, Propen Fall 2012 Membro de Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 3,592
