Ir para o conteúdo principal
Tea Kettle Switch Replacement
O que você precisa
  1. Tea Kettle Switch Replacement, Switch: passo 1, imagem 1 %32 Tea Kettle Switch Replacement, Switch: passo 1, imagem 2 %32 Tea Kettle Switch Replacement, Switch: passo 1, imagem 3 %32
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: passo 2, imagem 1 %32 Tea Kettle Switch Replacement: passo 2, imagem 2 %32
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: passo 3, imagem 1 %32
    • Click the replacement switch back into the handle part.
  4. Tea Kettle Switch Replacement: passo 4, imagem 1 %32
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: passo 5, imagem 1 %32
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: passo 6, imagem 1 %32
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
Conclusão
6 outras pessoas executaram este guia.
3 comentários
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Responder
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 33
Últimos 30 dias: 140
Duração total: 25,286
