Ir para o conteúdo principal
Tara Handle Replacement
  1. Tara Handle Replacement, Handle: passo 1, imagem 1 %32
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Handle Replacement: passo 2, imagem 1 %32 Tara Handle Replacement: passo 2, imagem 2 %32 Tara Handle Replacement: passo 2, imagem 3 %32
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Handle Replacement: passo 3, imagem 1 %32 Tara Handle Replacement: passo 3, imagem 2 %32
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Handle Replacement: passo 4, imagem 1 %32 Tara Handle Replacement: passo 4, imagem 2 %32
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Handle Replacement: passo 5, imagem 1 %32 Tara Handle Replacement: passo 5, imagem 2 %32 Tara Handle Replacement: passo 5, imagem 3 %32
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Handle Replacement: passo 6, imagem 1 %32 Tara Handle Replacement: passo 6, imagem 2 %32
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Handle Replacement: passo 7, imagem 1 %32 Tara Handle Replacement: passo 7, imagem 2 %32
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
Conclusão
Sam Goldheart
Membro desde: 10/18/12
475.162 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.803 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 296
