Introdução
Use this guide when you need to replace your display due to a clumsy mistake.
O que você precisa
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Unscrew the 2 Philips #00 screws from the bottom edge of the screen component.
Quase terminado!
Conclusão
