Introdução
Use this guide when you need to remove the motherboard in order to figure out internal problems within your device or replace it with another motherboard.
O que você precisa
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Quase terminado!
Conclusão
