Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the four Torx T5 screws from the back panel.
Wedge a spudger in between the front and back panel.
Apply leverage downwards to the spudger in order to remove the back panel.
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
Unscrew the 2 Philips #00 screws on each end of the motherboard.
Unscrew the 2 Philips #00 screws on each side of the charging port.
Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
Grasp the upper left edge of the motherboard and slide diagonally up and left away from the auxiliary port entrance.
Unscrew the 2 silver Philips #00 screws from both sides of the directional pad component on the front casing.
Take out the 2 pieces of the directional pad with tweezers.
Uma outra pessoa concluiu este guia.
