Ir para o conteúdo principal
Tagital T9X Camera Replacement
O que você precisa
  1. Tagital T9X Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Camera Replacement: passo 2, imagem 1 %32
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Camera Replacement, Camera: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, carefully remove the cloth covering from the ribbon connector for the camera.
  4. Tagital T9X Camera Replacement: passo 4, imagem 1 %32
    • Use the tip of the spudger or your fingernail to flip up the small flap on the ZIF connector.
    • Carefully remove the ribbon cable from the connector.
  5. Tagital T9X Camera Replacement: passo 5, imagem 1 %32
    • Remove the camera from its position at the top of the tablet.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 146
