Ir para o conteúdo principal
Tagital T9X Battery Replacement
O que você precisa
  1. Tagital T9X Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Battery Replacement: passo 2, imagem 1 %32
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Battery Replacement, Battery: passo 3, imagem 1 %32
    • Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
    • The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 338
