Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide shows the reader how to remove the case from the Tagital T7X and replace the battery. This repair is often done to replace a battery that has lost its ability to hold a charge. The battery is directly connected to the motherboard, meaning basic soldering skills are necessary.
O que você precisa
Place the Tagital T7X on a sturdy surface.
Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
Uma outra pessoa concluiu este guia.
Um comentário
We're can I get a battery? And I don't think the part should have died in less than a year . The battery lasted less than 6 mos. I bought the tablet for my mom to play cards on and that's it .She doesn't go on line. I put a book on it before I gave it to her and that is it. She doesn't even use it every day . What's the deal?
