Ir para o conteúdo principal
Tagital T10 Camera Replacement
O que você precisa
  1. Tagital T10 Camera Replacement, Camera: passo 1, imagem 1 %32
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4 mm Phillips head screws at the top of the device.
  2. Tagital T10 Camera Replacement: passo 2, imagem 1 %32
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
  3. Tagital T10 Camera Replacement: passo 3, imagem 1 %32
    • Pull the black tape away so that the rear-facing camera is no longer attached to the device.
  4. Tagital T10 Camera Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull off the plastic camera cover with the tweezers so that the front-facing camera can move freely.
  5. Tagital T10 Camera Replacement: passo 5, imagem 1 %32
    • Locate the small ZIF connector that connects to the cameras.
    • Use the plastic prying tool to pull up the black tab, so that the filament is released. Carefully pull the filament out so it is moving freely.
    • The camera can now be lifted from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Destin Dawsy
Membro desde: 09/26/16
328 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-5, Eyestone Fall 2016 Membro de USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 215
