Introdução
This guide shows how to remove and replace the pump assembly as a unit for the TackLife GSW01A Pressure Washer.
You have to remove the output assembly from the pump in order to replace the pump assembly. This requires removing many tight bearings, so having the proper tools will speed up the process.
The following tools are optional, but can help with disassembly:
- 1 × Channellock Groove Joint Pliers or Vise-Grips
- 1 × Hammer
- 1 × Cleaning Rag
O que você precisa
3 outras pessoas executaram este guia.
2Comentários do guia
I'm getting milky oil I want to change pump on my tacklife pressure washer 3200 psi what is a good pump?I cant find OEM pump from the number on pump?What size shaft?
My pump leaks. Do you know of a gasket kit? What type of replacement oil is used thank you
