Ir para o conteúdo principal
TOSHIBA Satellite E45W-C4200X TrackPad Replacement
O que você precisa
  1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: passo 1, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: passo 1, imagem 2 %32
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 2, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 3, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 3, imagem 2 %32
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 4, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 4, imagem 2 %32
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 5, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 5, imagem 2 %32
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 6, imagem 1 %32
    • Remove the battery from the laptop.
  7. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, TrackPad: passo 7, imagem 1 %32
    • Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
  8. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 8, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 8, imagem 2 %32
    • Use the spudger to peel up the keyboard cover.
    • Use caution when removing keyboard cover.
  9. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 9, imagem 1 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 9, imagem 2 %32 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 9, imagem 3 %32
    • Use the heat gun to apply heat to the track pad and use the metal spudger to remove the track pad.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 307
