Ir para o conteúdo principal
TOSHIBA Satellite E45W-C4200X Keyboard Replacement
O que você precisa
  1. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Cooling Fan: passo 1, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 2, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 3, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 4, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 5, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 5, imagem 2 %32
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 6, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 6, imagem 2 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 6, imagem 3 %32
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
  7. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Motherboard: passo 7, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Motherboard: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Unplug the connection to the battery.
    • Mark sure you are using the anti-static wrist strap for the duration of this replacement.
  8. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 8, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 8, imagem 2 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 8, imagem 3 %32
    • Remove all remaining external wire harnesses from the circuit board.
    • It is recommended that you use labels or take pictures of the wires you remove to assist in the re-connection.
  9. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the three screws from the metal bracket on the left side of the circuit board using a Phillips #1 screwdriver.
    • Remove the bracket.
  10. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 10, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 10, imagem 2 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 10, imagem 3 %32
    • Remove the two screws from the black plastic cover using a Phillips #1 screwdriver.
    • Remove the black plastic cover.
  11. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 11, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 11, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the remaining two screws holding the circuit board in place.
    • Carefully remove the motherboard from the device.
  12. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Keyboard: passo 12, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Keyboard: passo 12, imagem 2 %32
    • Remove the two 1 mm screws from the black plastic cover using the Phillips #1 screwdriver.
  13. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 13, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 13, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the three 0.5 mm screws from metal bracket.
  14. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 14, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 14, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the 44 (forty four) 0.5 mm screws on the existing silver panel.
  15. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 15, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: passo 15, imagem 2 %32
    • Pull up on the black tab that is on the silver panel to remove the keyboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 600
