Introdução
This guide documents the replacement of the transmission assembly for a 30" Toro TimeMaster Lawmower (21199). This transmission (part #131-9665) can be found at https://www.themowershop.com/product/tor... .
This is a moderately difficult replacement that will take approximately 2 1/2 hours and potentially require a few niche tools to be purchased.
Successful completion of this replacement will fix the self drive system.
O que você precisa
Remove spark plug wire and spark plug using a 5/8" socket to prevent accidental ignition of mower.
Set tire-height adjustment lever to forward-most position (past "A").
Re-attach the drive cable at the cable mounting point of the new transmission.
Flip the lawnmower back to its original position.
Place the scissor jack and wood blocks to support the lawnmower.
Re-install the wheel bearing and bolt on the right-side wheel using a 1/2" socket wrench.
On the other side, re-install the height adjustment lever, wheel bearing, and bearing bolt using a 1/2" socket wrench.
Use a 5/8" socket wrench to re-install the spark plug.
Re-attach the spark plug cable.
4 outras pessoas executaram este guia.
2Comentários do guia
Is there supposed to be a return spring on the other end of the lever that the traction cable attaches to?
On mine, it was just throttle cable to transmission and belt drive. There are some return springs just to help stabilize the transmission housing (see steps 18-22)
