Introdução
This guide will show you how to install batteries into a TI-Nspire calculator to ensure that it will turn on.
Ferramentas
Nenhuma ferramenta especificada.
Peças
Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
Slide the front cover down to remove it.
Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
Slide the switch until it moves from the left side of the button area all the way to the right side.
Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
To reassemble your device, follow these instructions in reverse order. If your calculator doesn't turn on, it could be that the keypad isn't connected properly. If so, refer to Connecting the Keypad.
6 outras pessoas concluíram este guia.
Um comentário
what should i do if it just stopped all of a sudden and my battery isn’t like that? Its a square not like A++
