Ir para o conteúdo principal
TI-89 Titanium Power Button Replacement
O que você precisa
  1. TI-89 Titanium Power Button Replacement, Power Button: passo 1, imagem 1 %32
    • Remove the six T6 screws from the back of the calculator.
  2. TI-89 Titanium Power Button Replacement: passo 2, imagem 1 %32
    • Remove the battery cover.
  3. TI-89 Titanium Power Button Replacement: passo 3, imagem 1 %32
    • Unscrew the Phillips screw on the internal battery cover.
  4. TI-89 Titanium Power Button Replacement: passo 4, imagem 1 %32
    • Using a spudger or similar prying tool carefully pop the back of the calculator off.
  5. TI-89 Titanium Power Button Replacement: passo 5, imagem 1 %32
    • Remove the back of the calculator.
  6. TI-89 Titanium Power Button Replacement: passo 6, imagem 1 %32
    • Remove the six Phillips head screws from the circuit board.
  7. TI-89 Titanium Power Button Replacement: passo 7, imagem 1 %32
    • Remove the circuit board and the attached display screen. Make sure not to damage the circuit board.
  8. TI-89 Titanium Power Button Replacement: passo 8, imagem 1 %32
    • Peel back the rubber grommet sheet.
    • Make sure that the buttons remain attached the the rubber grommet as you remove it.
  9. TI-89 Titanium Power Button Replacement: passo 9, imagem 1 %32
    • Remove and replace the On button.
Conclusão
Dan Stahl
Membro desde: 10/01/17
156 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Thank you, fixed my sticky keys / juice spill damage.
Martin Såsser - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 4,696
