Ir para o conteúdo principal
TI-84 Plus Silver Edition Faceplate Replacement
  1. TI-84 Plus Silver Edition Faceplate Replacement, Faceplate: passo 1, imagem 1 %32
    • Insert your index finger in the open slot below the keys.
    • Be careful to not bend the plate too much because it is very thin and might break.
    • Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
  2. TI-84 Plus Silver Edition Faceplate Replacement: passo 2, imagem 1 %32
    • Grab the face plate on each side near the middle and apply a gentle upward force on each side until the middle tabs come off.
    • A tab is located in the center of the face plate. If it is still attached, then continue to apply a gentle upward force until the center tab comes off.
    • Lift the face plate upward until the top three tabs come off and the face plate is completely detached.
Conclusão
6 outras pessoas executaram este guia.
Agustin
Membro desde: 10/20/13
1.041 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-34, Amido Fall 2013 Membro de Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 10,633
