Ir para o conteúdo principal
TI-84 Plus Silver Edition Backup Battery Replacement
O que você precisa
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: passo 1, imagem 1 %32 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: passo 1, imagem 2 %32 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: passo 1, imagem 3 %32
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: passo 2, imagem 1 %32
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: passo 3, imagem 1 %32
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: passo 4, imagem 1 %32
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: passo 5, imagem 1 %32 TI-84 Plus Silver Edition Backup Battery Replacement: passo 5, imagem 2 %32
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
Conclusão
17 outras pessoas executaram este guia.
Agustin
Membro desde: 10/20/13
1.028 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-34, Amido Fall 2013 Membro de Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
Membros da 4
Autoria de 6 guias
9 comentários
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Responder
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Responder
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Responder
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 57
Últimos 30 dias: 281
Duração total: 65,819
