Ir para o conteúdo principal
TI-36X Pro Battery Replacement
O que você precisa
  1. TI-36X Pro Battery Replacement, Back Cover: passo 1, imagem 1 %32 TI-36X Pro Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the calculator's protective cover.
    • Place the calculator face down.
    Pergunte ao FixBot
    Comentar
  2. TI-36X Pro Battery Replacement: passo 2, imagem 1 %32 TI-36X Pro Battery Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
    • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
    Pergunte ao FixBot
    Comentar
  3. TI-36X Pro Battery Replacement, Battery: passo 3, imagem 1 %32 TI-36X Pro Battery Replacement, Battery: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
    • Remove the battery cover without disconnecting either end of the blue wire.
    • Use your finger to move the battery cover to the side.
    Pergunte ao FixBot
    Comentar
  4. TI-36X Pro Battery Replacement: passo 4, imagem 1 %32
    • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
    • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
    Pergunte ao FixBot
    Comentar
Conclusão
11 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 11-52, Amido Spring 2014 Membro de Cal Poly, Team 11-52, Amido Spring 2014
CPSU-AMIDO-S14S11G52
4 Membros
Autoria de 10 guias
5Comentários do guia
Interesting that the cr2032 battery is not rechargeable, so is the solar panel real? Or does it bypass the battery and use the solar panel in lighted situations?
frogman896 - Responder Compartilhar
The guide should specify that the CR2032 needs to be rechargeable. They are readily available at a popular online shopping website. I was skeptical that the solar was real too, because of the frosted plastic placed over it. Based on the pictures in this teardown, and another video showing a red LED in the solar circuit, I conclude that the solar charging circuit is real.
Jacob Ertel - Responder Compartilhar
The manual doesn't specify a rechargeable battery. It just says a CR2032 Lithium battery. Unless all such batteries are rechargeable? I guess I'll find out since I just replaced the battery in mine and it's an Energizer CR2032, but it doesn't appear to say rechargeable anywhere on the packaging or the battery itself. I guess if it kills my calculator, it had a good run....
EDIT: The original battery that I took out of the calculator doesn't say rechargeable on it either.
Marc W - Responder Compartilhar
good guide, I'd just like to add that in my case I needed to press the "Reset" button for my calculator to start up again
Greg B - Responder Compartilhar
yeah but I have done that 3 times and now my calculator is officially announced dead....
Danielle Kennedy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 32
Últimos 30 dias: 141
Ao todo: 36,980
