Ir para o conteúdo principal
TDK Life on Record Trek Max A34 Battery Replacement
O que você precisa
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: passo 1, imagem 1 %32 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: passo 1, imagem 2 %32
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: passo 2, imagem 1 %32 TDK Life on Record Trek Max A34 Battery  Replacement: passo 2, imagem 2 %32
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: passo 3, imagem 1 %32 TDK Life on Record Trek Max A34 Battery  Replacement: passo 3, imagem 2 %32 TDK Life on Record Trek Max A34 Battery  Replacement: passo 3, imagem 3 %32
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: passo 4, imagem 1 %32 TDK Life on Record Trek Max A34 Battery  Replacement: passo 4, imagem 2 %32
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: passo 5, imagem 1 %32
    • The battery is now separated from the device and may be replaced with a new battery.
Conclusão
8 outras pessoas executaram este guia.
Kayla
Membro desde: 09/28/15
315 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 19-3, Rauch Fall 2015 Membro de Texas Tech, Team 19-3, Rauch Fall 2015
TTU-RAUCH-F15S19G3
Membros da 4
1 Guia de autoria
2 comentários
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - Responder
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 50
Duração total: 11,343
