Ir para o conteúdo principal
TDK Life on Record Trek 360 Battery Replacement
O que você precisa
  1. TDK Life on Record Trek 360 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
    • Before beginning this guide, be sure that the battery is completely drained of charge. This prevents electrical injury.
  2. TDK Life on Record Trek 360 Battery Replacement: passo 2, imagem 1 %32 TDK Life on Record Trek 360 Battery Replacement: passo 2, imagem 2 %32 TDK Life on Record Trek 360 Battery Replacement: passo 2, imagem 3 %32
    • Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
    • Pull down like a lever while continuing to apply downward pressure.
  3. TDK Life on Record Trek 360 Battery Replacement: passo 3, imagem 1 %32 TDK Life on Record Trek 360 Battery Replacement: passo 3, imagem 2 %32
    • Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
    • These images show the use of a metal spudger. Use a plastic opening tool or standard spudger to prevent damage to your device.
    • The battery does not lift STRAIGHT UP. Lifting in this manner could damage the battery, wires, and/or the device.
  4. TDK Life on Record Trek 360 Battery Replacement: passo 4, imagem 1 %32 TDK Life on Record Trek 360 Battery Replacement: passo 4, imagem 2 %32 TDK Life on Record Trek 360 Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
    • Take extreme caution when pulling. This requires some force, but pulling with extreme force can cause damage to the wire/battery/or device.
Conclusão
3 outras pessoas executaram este guia.
Helen Huynh
Membro desde: 09/14/15
338 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-2, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
Membros da 3
Autoria de 5 guias
2 comentários
Good guide, but what battery fits?
Niklas Aronsson - Responder
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
Barbafant Fant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 3,663
