Ir para o conteúdo principal
TDK Life on Record A33 Speaker Replacement
O que você precisa
  1. TDK Life on Record A33 Speaker Replacement, Speaker Guard: passo 1, imagem 1 %32
    • Push the nylon or metal spudger in the corner of the speaker guard.
  2. TDK Life on Record A33 Speaker Replacement: passo 2, imagem 1 %32
    • Slowly lift the speaker up enough so that you can slide around the speaker guard.
  3. TDK Life on Record A33 Speaker Replacement: passo 3, imagem 1 %32 TDK Life on Record A33 Speaker Replacement: passo 3, imagem 2 %32
    • Slide the nylon or metal spudger all around the speaker guard.
  4. TDK Life on Record A33 Speaker Replacement: passo 4, imagem 1 %32
    • Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
  5. TDK Life on Record A33 Speaker Replacement, Speaker: passo 5, imagem 1 %32 TDK Life on Record A33 Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Remove all (4) 3mm screws in the middle speaker using a Phillip's head screwdriver.
    • You can also remove the speakers on the left and right.
  6. TDK Life on Record A33 Speaker Replacement: passo 6, imagem 1 %32 TDK Life on Record A33 Speaker Replacement: passo 6, imagem 2 %32
    • Do not rip the wires inside the speaker when trying to open the middle speaker on the device.
    • Create an opening in the speaker by holding the device up and carefully grabbing the side of the speaker that pops out.
  7. TDK Life on Record A33 Speaker Replacement: passo 7, imagem 1 %32 TDK Life on Record A33 Speaker Replacement: passo 7, imagem 2 %32
    • Wear safety goggles and have something to absorb the smoke from the soldering iron just in case.
    • Do not burn the wires of the speaker.
    • Remove the solder that connects the wires to the speaker. You should be able to now remove the speaker and replace it.
Conclusão
Matthew Phou
Membro desde: 10/20/15
448 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
Membros da 4
Autoria de 5 guias
3 comentários
Where can I buy the woofer?
stevealvarado54 - Responder
Really, stevealvarado! What's The point of taking this all apart if you don't have a replacement to put in?
Van Moon - Responder
If l need a second opinion about which speaker is blown, who or where can can l get it diagnosed?
Tony - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 4,420
