Introdução
Replacing the battery is a fairly straightforward and easy process, which may need to be done if the device isn't charging or isn't turning on. A replacement battery, which can be obtained from the TDK website, is needed, along with a Torx screwdriver. Be gentle when working around the wires, as they are fairly thin and can break easily. Overall, this is an easy fix which almost anyone can do.
O que você precisa
Remove all (6) 5mm Torx (Star) screws on the bottom panel of the device using the T4 screwdriver.
20 outras pessoas executaram este guia.
5 comentários
This was a GREAT tutorial.
I did find on step 3 that I could not dislodge the cover with my fingernails. I had to use a jeweler's screwdriver to carefully pry it loose. I also found that it was easier to put the new battery in flat end first and then laying it down and putting the wires into the pocket.
Thanks for sharing.
Beautifully done, 5 star
Use the T5 Not T4
