Introdução
The AC adapter can be taken apart using a quick process shown here. This can be used to replace the prongs on the AC adapter or remove them from the bulky portion so you can bend them back into place. In order to take the prongs off, a slim, sharp object is required.
O que você precisa
Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
Uma outra pessoa concluiu este guia.
