Ir para o conteúdo principal
TDK Life on Record A33 AC Adapter Prongs Replacement
O que você precisa
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: passo 1, imagem 1 %32
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: passo 2, imagem 1 %32 TDK Life on Record A33 AC Adapter Prongs Replacement: passo 2, imagem 2 %32
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: passo 3, imagem 1 %32
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Festa
Membro desde: 10/16/15
808 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 2,546
