Introdução
How to re-calibrate the Yoke, in case the Pitch and Roll Axis, Mini-stick and/or throttle levers are not providing correct input
This calibration can be performed on PC and on Xbox.
Set the switch at the back of the Yoke to PC position.
Don't forget to switch it back to Xbox, once you have completed this guide.
Make sure that Roll and Pitch are at resting point.
Make sure the right mini-stick is at resting point.
Make sure that Throttles are in the middle
Press and hold the buttons highlighted in the image
Connect the Yoke to USB port while holding the buttons.
Once the Xbox button starts flashing, release the buttons.
Move the Yoke to the right, until you reach maximum.
Return the Yoke to Center.
Move the Yoke to the left, until you reach maximum.
Push the Yoke forward, until you reach maximum.
Pull the Yoke towards yourself, until you reach maximum.
Move the mini-stick to the right, until you reach maximum.
Return the mini-stick to Center.
Move the mini-stick to the left, until you reach maximum.
Move the mini-stick up, until you reach maximum.
Move the mini-stick down, until you reach maximum.
Press Xbox button to finish the calibration.
Xbox button should stop flashing.
