Ir para o conteúdo principal
TCA Sidestick X Flash and re-install the firmware
O que você precisa
    • Download and install the drivers from here.
    • Both the Sidestick and the Quadrant are using the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Sidestick from USB
  1. TCA Sidestick X Flash and re-install the firmware, Switch to PC mode: passo 4, imagem 1 %32
    • Set the switch at the back of the TCA Sidestick to PC mode.
  2. TCA Sidestick X Flash and re-install the firmware, Press and hold the XBOX button: passo 5, imagem 1 %32
    • Press and hold the XBOX button.
    • Keep holding the XBOX button and connect it to USB port of your computer.
    • Once connected, wait a few seconds and let go of the button
    • Your Sidestick should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete
Linha de Chegada
Formica Fusca
Membro desde: 08/01/24
2.595 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 158
