Ir para o conteúdo principal
TCA Quadrant Flash and re-install the firmware
O que você precisa
    • Download and install the driver package from here.
    • Both the Sidestick and the Quadrant are using the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your Quadrant from USB if you already have it plugged-in
  1. TCA Quadrant Flash and re-install the firmware, Press and hold the indicated button.: passo 4, imagem 1 %32
    • Press and hold the button highlighted in the image.
    • Keep holding the button and connect the Quadrant directly to USB port of your PC.
    • Connection must go directly to USB port of your PC and not through the Sidestick
    • Your Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
Linha de Chegada
Formica Fusca
Membro desde: 08/01/24
2.595 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 37
Ao todo: 370
